주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
The Epson WF-2540 is an all-in-one color inkjet printer. It features a 2.5-inch LCD touchscreen and four individual ink cartridges.
showing paper jam message
My epson wf 2540 is showing a paper jam message and there isnt a jam
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 1개
Try the following methods to fix paper jam error:
  • Unplug your printer while it is on. Leave it for approx 30 min. Plug it back on. Sometimes this might resolve the issue.
  • Sometimes there is might be something probably inside your printer in some positions which blocks the paper sensor along the paper path in that positioned you can't see.
  • Remove the toner cartridge( if you are using) and shake your printer up and downside gently and carefully.Remove all ink cartridges and reinstall them one at time. Move the carriage over to far left and back in position. Re-position the encoder strip of print head carriage.
  • Ensure that your paper tray must not be over filled. Verify that papers are not packed too much tightlyin paper tray.
I hope with all these tips you might resolve your issue. If still it shows paper jam error that means there is hardware failure. But don't worry check Epson Workforce Wf-2540 Manual for diagnosing and troubleshooting your printer.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Kirk Bell 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 11
전체 시간: 6,837
