The Nintendo 2DS is a handheld gaming device developed as an entry level version of the Nintendo 3DS with nearly identical hardware, but without the 3D upper screen function.
you dont need to cut any cables, you can setup a PIN code to access the options and just delete all the internet connections and set the pin code up so that nobody can access the settings to setup a connection, pretty much the same effect as removing the WIFI antenna..
Other answers say parental controls. That solution does not work for me. The child still can call nintendo to disable them..
Samuel Hilton 의
