How to fix a "camera error" on my camera?
I send my Sony @57 in the repair but they said its working fine but now the camera error is keep on coming back. It seems like there are some connections that is loose on it because every time the camera error appears the other buttons wont work then if you press it a couple of times the camera is making a wired sound then the lcd will appear.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 1개:
was looking at an engineer who took his apart on u tube he discovered a little screw beside the shutter button is causing the problems with error message
screw becomes loose. from the dearest to cheep sonny cameras. sonny know of this problem. sonny wont acknowledge. far to expensive to send for fix to sonny. cost more than the price of the camera that why the chap took apart
댓글 달기
