주요 콘텐츠로 건너뛰기
2014년 9월 19일에 출시된 이 5.5” 스크린 iPhone은 iPhone 6의 큰 버전입니다.
1526 질문 전체 보기
Replacing A8 chip with corresponding home button
I recently replaced my home button to find out that my touch id no longer works
What if i buy an A8 chip with the corresponding home button will it work then?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 2개
Do you know how to do micro soldering and do you have a microscope, solder wire, flux, soldering iron, rework station?
@benjamen50 No and it was pretty ripped apart i googled microsoldering and i dont think it would have worked
댓글 달기
답변 1개
가장 유용한 답변
Ibo you can not replace just the CPU. The CPU is tied to to the nand memory with the serial number of the device, the modem, home button and the eeprom baseband memory on the i6 I would forget about your touch id! the CPU is only reworked for data recovery purposes due to the amount of work involved. If you can't live without it you would be better to replace the phone. There is a A8 sn programmer but it is not on the market yet.
해당 답변은 도움이 되었습니까?
점수 1
댓글 3개:
Oh thank you so much
Btw do you know when it will be in the markets?
i use JC programmers for Nand and eeprom repairs. on the JC software package they show they have produced it but nowhere i can find that it available for purchase. i will find you a link though
ibo here is the link for the A8 Serial number programmer
http://www.jcxxkeji.com/qingyumi/product...
댓글 달기
귀하의 답변을 추가하세요
ibo 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 11
전체 시간: 762
