주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
A television game console produced by Sony Computer Entertainment, also known as PS4. First announced February 20, 2013 and released November 15, 2013.
Ps4 model CUH-1115A Question
So I have two ps4's...both are broken in a way, the CUH-1001A has a dead power supply unit, it won't even turn on...
I also have a ps4 model CUH-1115A..it turns on and I can play Dvds in it, but the blu ray reader is burnt out...will my disk drive from my CUH-1001A work on my 1115A model?
I know the power supply from the 1115A model won't fit in the 1001A model,so that's dead....
Any answers would be appreciated.!
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 2개
선택된 해법
According to this, yes.
http://www.newegg.com/Product/Product.as...
Also if you need a power supply for the other one:
https://www.amazon.com/Original-ADP-240A...
이 답변이 도움이 되었나요?
점수 2
댓글 2개:
If I happened to put the wrong disk drive in would it harm my ps4?
Due to the redesign, I don't think it would fit right if it were the wrong one.
댓글 달기
You MIGHT be able to swap disc drives. There are several things to keep in mind:
1) Be sure that you keep the drive board from the disc drive with the motherboard that it came with. They are married and cannot be swapped.
2) You need to make sure that the wide ribbon cable that goes inside the disc drive will fit onto the drive board from the swapped drive. There are two different styles and they aren't the same size.
As long as you do those two things you'll be fine.
PS. Yes, the power supplies are not interchangeable.
Hope this helps.
이 답변이 도움이 되었나요?
점수 2
댓글 달기
답변을 추가하세요
Bryan Lee 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 6
지난 30일: 28
전체 시간: 4,609
