주요 콘텐츠로 건너뛰기
8.9" tablet, co-developed by Google and HTC. First released in November 2014, running Android 5.0 Lollipop.
29 질문 전체 보기
Sudden refusal to charge
After a couple of years of 'no problem' day to day' use, my Nexus 9 has suddenly died. I don't think think it was 'mid use death' , it hasn't been dropped etc and is in excellent condition.
I suspect that it ran out of battery and now is refusing to charge. I'm not even getting the white flash when in a very low battery state.
Before I buy a replacement battery, does anyone have any suggestions?
Ive tried every combination of button pressing to boot to different states, bit I suspect it's a batter issue.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 3개
선택된 답변
I have no suggestions except replace your battery. I'm pretty sure that your battery is completely dead.
해당 답변은 도움이 되었습니까?
점수 1
댓글 4개:
Just a quick update, my new battery arrived today, fitted it and booted first time.
Yay!!! Glad your phone is back to working condition :)
Phone? The Nexus 9 isn't a phone, it's a tablet. I don't even think it has 3G/4G capabilities. What do you mean?
David. Just a question. Where did you find a Nexus 9 battery? It is a nightmare to find....
댓글 달기
가장 유용한 답변
@davidtjackson you may want to check that your chargers working . Check your cable try it with another one, check the port that theres no lint or dirt preventing the cable from connecting properly . If you have access to another charger try it . You may also want to reseat the battery as it can sometimes just need to make a new connection to work again and recharge. These are a few things Id try before buying a new battery. Hope this helps
해당 답변은 도움이 되었습니까?
점수 3
댓글 달기
Thanks both,
I've managed to rule out it being a faulty cable. I've found a replacement battery - so hopefully it'll be that. I'd have expected it to last longer than a couple of years, but I suppose these things just die every so often.
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
Glad to help. And sadly yes, rechargeables only have so many charges in their lifetime.
댓글 달기
귀하의 답변을 추가하세요
David Jackson 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 2
전체 시간: 166
