주요 콘텐츠로 건너뛰기
Announced October 22nd and released November 12th, 2013. The iPad mini 2, also known as the iPad mini with Retina Display, has all the pixels of the iPad Air in a smaller 7.9" form factor.
My digitizer is dimming after I repaired my screen?
After I replaced my glass screen the digitizer has become dim. I can see the apple sign when I turn it on. And when I try to turn it off I can see the X button where you would exit powering off. What do I do?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 1개
I have to look at the screen in the light. What is the back light? Or where is it.
댓글 달기
답변 1개
선택된 해법
How dim is the screen? Make sure the brightness is turned up. Make sure the connector are properly connected. You could try a soft reset. Does the LCD display an image when it goes to the home screen, or do you have to be in light or turn the iPad a certain way to see what's on the display, if that's the case the black light fuse may need to be replaced.
이 답변이 도움이 되었나요?
점수 2
댓글 3개:
Cues it's the back light than. Because I have to look in the light to see the screen. Where would the back light be at?
Ooh it's the backlight diode filter
@theimedic, you should turn that into an answer.
댓글 달기
답변을 추가하세요
Sharla Coleman 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 2
지난 30일: 3
전체 시간: 95
