주요 콘텐츠로 건너뛰기
Sony ICFC1T alarm clock/radio is manufactured so that in the event of a power outage, you have the peace of mind that your device will continue working so you never miss an event.
24 질문 전체 보기
Why does my Sony ICFC1 clock flash "OFF" on display & not keep time?
My Sony ICFC1 alarm clock has been continuously flashing between the time and "OFF" on the display. Also, the buttons on the back to set time do not correspond with one another.
why would my clock flash this way, also flashes cycle of date as if setting time and has been keeping incorrect time.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 4개
my guess the battery needs replacement????????????????
Tried everything suggested and nothing works. All I want is the correct time.
Just purchased cube clock radio. Can't get time set to am. No matter what time i set its pm!
@Ann Hearn
What is the make and model number of the clock if it is not a Sony ICF-C1T?
댓글 달기
답변 1개
선택된 답변
Hi,
Try a power reset and see if this resolves the problem.
Turn off the AC power to the clock.
Remove the coin cell backup battery from the clock.
Press and hold the Enter/Time Set button for 10 seconds and then release.
Reinsert the coin cell battery and then switch on the AC power and see if you can adjust the time etc.
Here is a link to the user guide for your clock/radio which shows how to remove the coin cell battery. Ensure that you insert it back into its' holder the correct way if it happens to become dislodged when out of the clock.
https://www.appliancesonline.com.au/publ...
해당 답변은 도움이 되었습니까?
점수 3
댓글 달기
귀하의 답변을 추가하세요
Andrew Arruda 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 10
30일 전: 50
전체 시간: 7,300
