주요 콘텐츠로 건너뛰기
2012년 9월 12일에 발표된 여섯 번째 Apple iPhone입니다. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 16, 32, 또는 64GB / 검정색 또는 흰색으로 제공하였습니다.
2522 질문 전체 보기
Back camera not working. (Replacement not works also)
So I bought a used iPhone 5 with back camera not working. I thought I will replace the camera and sell it for the profit. The problem is, that I replaced the camera, and it still doesn't work. I thought maybe the replacement was broken too, so I found one more camera, replaced it again and IT STILL DID NOT WORKED. Decided to use it for a couple of days. After 2 hours it started to work. By then I thought everything is going to be OK, but after a couple days it is not working again.. Been using it with defective camera for 3 days now. Flash is not working too. In the camera app it displays yellow triangle in the upper left corner, which says "The iPhone needs to cool down to use the flash" (something like that). What could the problem be???
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
가장 유용한 답변
I thing that the problem is on the motherboard. You will have defective control IC on your motherboard probably. Is your front camera function?
해당 답변은 도움이 되었습니까?
점수 1
댓글 3개:
front camera works. Only don't work compass and proximity sensor. I tried swapping front cameras for priximity sensor to work. That did not help either
Interment issues usually points to a bad switching component on the board like he said. Camera ic is one of the most common failures.
So the solution would be to replace the motherboard ?
댓글 달기
Unless you have experience in rework or have replaced ic before then yes you would need a new motherboard
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
tomas.ukrinas1997 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 1
전체 시간: 67
