Why is it starting to slow down?
mini mac late 2012
좋은 질문입니까?
I Recommend Upgrading To 8GB Ram And A Solid State Drive That Would Make You Mac Mini Run Smoother Especially If You Are On Mac OS X 10.12.0 Or Above
이 답변이 도움이 되었나요?
You hard drive is to full. Anytime you get a drive more than 80% filled it will start to slow down.
Standard RAM: 4 GB Maximum RAM: 16 GB
Details: By default, 4 GB is installed as two 2 GB modules.
This model supports 16 GB of RAM using two 8 GB modules.
I would also recommend a Seagate SSHD 1 TB. Use the existing drive for storage.
Or
adding a smaller SSD drive and turning it into a Fusion Drive.
But you may to clean up the drive and eliminate duplicate items or whatever is taking up your HD space.
Here's how to add the second drive.
이 답변이 도움이 되었나요?
지난 24시간: 0
지난 7일: 3
지난 30일: 6
전체 시간: 1,349
댓글 5개
Whats The Specs On It ?
Justin R 의
2.5 GHz Intel Core i5
4 GB 1600 MHz DDR3
Intel HD Graphics 4000 1536 MB
Ben Osterlund 의
Do You Have The Storage And How Much Is Used
Justin R 의
5 gigs, 418 still available
Ben Osterlund 의
Standard Hard Drive: 500 GB (5400 RPM) Int. HD Interface: Serial ATA (6 Gb/s) x2
mayer 의
