dome light does not work?
dome light works when passenger door is opened but not when drivers door is opened? checked button it is ok.
좋은 질문 입니까?
좋은 질문 입니까?
steven white , If passenger door puts the light on and you tested the light button on the drivers door and found it to be good, you will have to trace and check the plug/wires from driver door switch for corrosion, bad grounding or bad/damaged/open wire. Good luck.
해당 답변은 도움이 되었습니까?
24 시간 전: 0
7일 전: 1
30일 전: 4
전체 시간: 462
