주요 콘텐츠로 건너뛰기
MacBook Pro 13" Retina Display, 모델 A1502의 2015년 3월 업데이트는 5세대 Intel Core i5 및 i7 프로세서를 포함하며 Force Touch 트랙 패드를 소개합니다.
MacBook Pro suddenly dead and does not turn on
Hello,
My Macbook Pro suddenly shut down and is not turning on, no chime, no Apple logo. There was no exposure to water. (However, I had kept a steaming bowl of hot water right next to the laptop.But this was in an open kitchen)
The Pro had less than 10% charge when it suddenly shut down. I charged it for another 10 minutes and tried to switch on, but no luck. I charged it completely till the magsafe indicator turned green, still does not turn on. So assumed that the battery is charging fine. I opened the mac and saw no visible corrosion or moisture(two tiny dots below the battery case are white and haven't turned red)
I have tried the following already.
1. SMC reset - With the magsafe adapter connected, when I do the reset the charge indicator turns green from orange.
2. Disconnected and reconnected the battery connector - still no life.
Its been only a year and three months I bought this in India. Could the logic board die out so soon? How to pinpoint if it is indeed the logic board?
Thanks a lot!
Update (01/23/2017)
I am currently based in a small town in Germany with no apple genius store around. I will be visiting the store in February. Meanwhile any help would be appreciated.
Thanks!!
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 30
댓글 35개
Disconnect the battery, then the keyboard, then plug in the charger and see what happens.
@madhu15 as Rany said, but reconnect the battery after disconnecting the keyboard. The 2015 13" will only boot when the charger is connected if the battery is plugged in too :)
If this doesn't work, remove the logic board and check the bottom for liquid damage.
Thanks for the prompt reply @reecee and @rany! I did the following in sequence
Disconnected battery --> pulled out keyboard cable --> reconnected the battery --> connected the charged.
Alas, nothing happened :(
@reecee I didn't know that. I thought it would start with charger alone. Point taken...
Try the same with trackpad disconnected...?
댓글 30개 더보기
댓글 달기
답변 11개
선택된 해법
When trying to attempt to boot it, press the trackpad. If it clicks, the MacBook is coming on (but is not displaying picture, chiming or another issue), if not, the MacBook is completely dead, which will be an issue with the logic board. The force touch trackpads will only click when the MacBook is on, so this is a good indicator when diagnosing these.
Remove the logic board and check it for any liquid damage. Remove the tape at the top of the board (this covers components, sometimes liquid is underneath this.
Clean any liquid with 95%+ isopropyl, but before cleaning, take a picture for reference, so we know what area was affected by the liquid (if the clean doesn't resolve the issues.
The MacBook should boot when the battery is reconnected and the charger plugged in, so there is clearly an issue with the logic board.
이 답변이 도움이 되었나요?
점수 21
댓글 30개:
Trackpad gives no click after reconnecting the battery and charger. So, as you said it is a logic board issue.
I'll try removing the board and see if there has been any accidental liquid spill without my knowledge.
Thanks
I have the same issue except my trackpad does click. But my screen is still black and heard no chime and my battery is fully charged
I had a similar issue, My Macbook Pro couldn’t switch on for over two weeks.
Finally I managed to resolve the problem and now it’s back and performing even better.
Follow this guide here: http://bit.ly/2qCKG0q
Hope this helps.
My macbook pro suddenly doesn't want to switch on nor charge. What should I do
Francis, I'm having the same issue and I wanted to check your link but it's broken. I hope you can see this message and send us an updated link. Thanks
댓글 25개 더보기
댓글 달기
가장 유용한 답변
Reset the SMC on Mac notebook computers
First, determine whether the battery is removable. Mac notebook computers that have a nonremovable battery include MacBook Pro (Early 2009) and later, all models of MacBook Air, MacBook (Late 2009), and MacBook (Retina, 12-inch, Early 2015) and later. Learn more about Mac notebook batteries.
If the battery is nonremovable:
Shut down your Mac.
Unplug the MagSafe or USB-C power adapter from your computer.
Using the built-in keyboard, press Shift-Control-Option on the left side of the keyboard, then press the power button at the same time. Hold these keys and the power button for 10 seconds.
Release all keys.
Reconnect the power adapter.
Press the power button again to turn on your Mac.
If the battery is removable:
Shut down your Mac.
Disconnect the MagSafe power adapter from your computer.
Remove the battery. (Learn about removing the battery in MacBook and MacBook Pro computers.)
Press and hold the power button for 5 seconds.
Reconnect the battery and MagSafe power adapter.
Press the power button to turn on your Mac.
The LED on MagSafe power adapters might change colors or temporarily turn off when you reset the SMC.
Reset the SMC on Mac desktop computers
Follow these steps for iMac, Mac mini, Mac Pro, and Xserve.
Shut down your Mac.
Unplug the power cord.
Wait 15 seconds.
Plug the power cord back in.
Wait five seconds, then press the power button to turn on your Mac.
Thanks
Varun
이 답변이 도움이 되었나요?
점수 50
댓글 64개:
Hi Varun,
As mentioned above, mine is an early 2015 retina Pro and hence battery is not removable. Already tried the SMC reset. No signs of life.
Thanks
Try With Reinserting The Battery Connector
Thanks
Varun
What is the battery connector? The battery is not removable.
Thanks it worked.
@Madhu: Does your Macbook work again? I have a similar issue. Apple says that I am out of warranty and the German shop notebooksbilliger.de don't feel the need to repair my MBP (finally I consulted a lawyer).
댓글 59개 더보기
댓글 달기
I have the same problems TODAY. No response from Mac Pro 13 “ Retina Early 2015 after holding down the power button. I try the SMC reset . Plug out the AC power. HOLD THE KEYS: SHIIFT, CONTROL, OPTION, AND POWER SIMULTANEOUSLY FOR 10 SECS. THEN Release. Hold down Power button for 15secs. It power up again. IT works !
이 답변이 도움이 되었나요?
점수 6
댓글 6개:
I tried that several times it didn’t work, I had to open Mac up and disconnect the battery plug
I then plugged in AC power it worked!
I then shut Mac down re inserted battery plug thinking the battery was the fault but it all works as normal!
I’ve gone through same process and it ain’t working , I use a MacBook pro 2017
Thanks a ton. it works for me
Hi, I have the exact problem you do. My MB Air will startup normally if I leave the internal battery connection unplugged and just use the charging cord with the amber light on. The Air will start normally even if I shut it down (sleep as well) and plug the charger cord in and push the power on button.
If I plug the internal battery into the logic board the Air will not start from the battery or the charging cord.
I don't know if a new battery will solve this issue. Have you solved the problem?
It is not working for me too on Macbook pro 15 inch 2011.
The CPU fan runs, I checke the Ram, the Harddrive in the other Laptops. Everythings semms to be fine. The Capslock light is also not turning on.
Can anybody Help please...
댓글 1개 더보기
댓글 달기
Had a similar issue on my 13” Macbook Pro (late 2013). The battery died while the laptop was left running and it wasn't powering bank on. None of the reset key combinations suggested would power it on.
An authorized service center diagnosed the issue (charged me about $30) and told me I had to replace the topcase (cost: $500+) - since there was a problem with the power button.
  • Upon opening up the laptop myself (since it was a 5 year old laptop at the time and warranty had already expired) using iFixit’s Pro Tech Toolkit (costs about $70) and disconnecting the battery and then plugging in the magsafe connector, it powered back on. I then put it back to sleep by closing the lid and connecting the battery back in.
I indeed seem have an issue with the power button but as long as I maintain charge in the battery I don't have to use the power button, I can just easily continue to put it to sleep and waking it back up using just the lid. Oh and I can also restart without any problems. It's only when I let battery die, or shutdown, that I have to open laptop, disconnect the battery, and repeat the process.
The original electronics toolkit: Designed for computer, smartphone, tablet, and gaming repair, backed by thousands of free instructions. 이미지
제품
Pro Tech Toolkit
$59.96
이 답변이 도움이 되었나요?
점수 2
댓글 2개:
This worked perfectly for me. After trying all of those resets, the SMC and P+R key reset, I wasn’t expecting unplugging the battery to do the trick. But it powered right up after I reconnected the magsafe charger.
Anyone who’s having issues with their a1502 MBP not turning on, but green light on the magsafe should try this fix. I guess my issue is only if I let the computer run out of battery entirely. Then I have to disconnect the battery, plug in charger and then hit the power button and it comes to life-like the above post, I can close the lid and plug the battery back in right after, and everything is good.
But, If I had just tried this earlier, it would have saved me a lot of stress. Thanks Siddharth!
This worked for me too!! I thought I was hooped. Got the A1502 model in late 2015 and was able to resurrect it with this! Disconnected the battery inside, plugged it in, reconnected the battery and bam! Start-up music :)
댓글 달기
For someone who doesnt work with all those method my macbook pro got green light on mag safe charger but always show up with red charger icon , try quickly move a bit of the charger then turn on suddenly ! I know its weird but its work for me
이 답변이 도움이 되었나요?
점수 1
댓글 2개:
Wow, how you discovered this thing! It worked flawlessly!
I tried all tricks mentioned here: 1) SMC Reset, 2) Power+Trackpad, 3) FN+Control+Command+Power, all without any avails, still, no chimes or power on, and the Magsafe charge indicator kept off like no electricity.
Then I tried your trick. Voila, it was ON!
Thank you for your discovery-of-the-century!
댓글 달기
Im having to do the same process of taking the back off and disconnect the battery and plugging into a wall outlet its really annoying but it does work,in this state my macbook is probably worth less then $100. Wondering what to do from here ? Buy new battery?
Update (05/13/2020)
You have to unplug the battery and plug it back in it will automatically start up don't let it shut off keep it charged keep it going cuz if it turns off going to have to unplug the battery and do all that again and that's a ##&&% taking that back off at everything so leave the motherfuker charging and you'll be good to go
이 답변이 도움이 되었나요?
점수 1
댓글 2개:
Actually, as long as it does not switch off and the battery does not go flat, it is fine ... so I can never let any of those situations happen!
Mine is a MacBook Pro from 2015, 15"
댓글 달기
Unfortunately I had the same issue. while working on my Mac air 13 , the battery died and after I had charged 100%, it still did not turned up. I tried all the options, however nothing worked. Ultimately, had to change the motherboard which was “costly”. I was told by apple care that there was a liquid found in the motherboard and hence it happened. It still does not seems to be a convincing reply to me. Seems to me it could be the moisture formed on some part in motherboard which could have caused it
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Replace the battery. .
Remove the battery and connect the power cable directly. Wait for 5 blinks on the led, and in 10 seconds the laptop will boot. It's definitely the faulty battery… don't ignore service battery. The faulty battery manifests in ways unimaginable and unbelievable..
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Open up. Ease the battery connector off with your finger/Nail…don't use a screwdriver!
Plug in mains and see if it boots up… if it does leave on for a minute to recover machine…then turn off and remove mains…insert battery connector….if your machine is a fixed battery and connector then it must need an Ap Technician.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
i dont know if this will help i had the same issue and nothing seemed to work all day i read loads of documents but still no joy with any of hte methods however the bit htat stuck in my mind for my 2016 mbp was htat the track pad was clicking for about 2 secods and then just tuen off. so i turned on the devise and just kept tapping on the track pad non stop till it booted . alsas it came on and im currently trying to reinstall a. new version of mojave
hope this helps
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
unfortunately it switched back off
im plannig on opening it up tomorrow
댓글 달기
Sometimes my Macbook pro forcefully auto shut down and did not power on.
Above no method works for me.
Finally worked it some other method.
  • Close your display and plugin for 7/8 hours.
  • Open display, my MacBook automatically powered on.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Madhu 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 47
지난 7일: 293
지난 30일: 1,526
전체 시간: 1,314,429
