주요 콘텐츠로 건너뛰기
LG 대형 스마트폰, 2014년 가을 출시. LG는 Quad HD IPS 스크린과 13-megapixel 카메라를 자랑합니다.
180 질문 전체 보기
Why won't cables fit my ports after phone was dropped in water?
I dropped my phone getting out of a vehicle last night, during a pretty heavy rainstorm. I looked for it for about an hour before I found it, facedown in a puddle. I carried it in, but bumped the screen, and it came on. (It was in a protective case, but not anything water-resistant, like an Otterbox.)
Everything worked, other than thinking that a device was plugged into the headphone port. Per an online search, I used a can of compressed air to blow out the port, and that icon went away.
Everything seemed fine, until I tried to plug my charger in. The cord would not fit. Same thing for the headphone jack. Any ideas on how to fix this? (Or clean it, in case mud is in there.)
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
You can try cleaning them out with isopropyl alcohol and a toothbrush, if that doesn't work then you probably need to replace the ports. The headphone jack is easy as it is modular so you can just pop it out and install a new one.
Follow this guide up to Step 9. LG G3 Screen Assembly Replacement
The charging port on the other hand is soldered onto the board so that would require soldering equipment and knowledge to desolder the old part and install a new one.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Jamie 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 19
전체 시간: 2,591
