주요 콘텐츠로 건너뛰기
2.2, 2.4, 2.5, 또는 2.6 GHz Core 2 Duo 프로세서
759 질문 전체 보기
Bezel cracked, display jumpy
The bezel on my wife's 2007 15-inch Core2Duo MacBook Pro has a crack just above the base on the right side. The display jumps a little. It doesn't flicker. I need some informed speculation before I try to replace anything. The jumpy display suggests some electronics or wiring is bad, but not necessarily that the display itself is bad. If I tackle this, what parts would probably see me through? Bezel. Wiring? Display?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
That models display frame usually breaks on the left side about an inch up from the bottom left hand corner as you are looking at the machine. @mactech has repaired a few of these and is better qualified than I to give you a comprehensive answer.
해당 답변은 도움이 되었습니까?
점수 3
댓글 달기
귀하의 답변을 추가하세요
bobball 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 2
전체 시간: 108
