주요 콘텐츠로 건너뛰기
The HTC Desire 626 is a mid-range Android smartphone released by HTC, a Taiwanese consumer electronics company, in March 2015.
15 질문 전체 보기
HTC Desire 626 Will Not Charge Or ReBoot
My HTC Desire Is Not Charging. In the past, I have had to do a soft reset (volume button and power button) however, it is not showing that screen anymore. It just saying Battery 0%. Now, I have had the battery charging all night and nothing has changed. Any help?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 1개
have you had to wiggle the charger previously to get it to charge? what is the battery voltage?
Update (01/26/2017)
use a multimeter set to voltage mode. if you have a universal battery charger you could charge it up for 15 minutes or so and that ought to get it up enough to work in the phone again if the voltage being too low is the issue. has to be at least 3.5V to charge in the phone, anything lower and it will not be recognized in the device.
해당 답변은 도움이 되었습니까?
점수 0
댓글 2개:
No. And how do I find the battery voltage?
The Voltage of the Battery (appears on the label) is 3.85v.
댓글 달기
귀하의 답변을 추가하세요
Nai 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 7
30일 전: 10
전체 시간: 1,093
