주요 콘텐츠로 건너뛰기
3 MB 공유 L3 캐시 1.7 듀얼-코어 Intel 프로세서 (Turbo Boost 최대 2.6 GHz).
139 질문 전체 보기
After replacement both new and old batteries won't charge.
My MacBook Air battery capacity got very low over time (Coconut battery has shown around 42% of design capacity). So I decided to replace it, I ordered replacement battery on eBay.
After installing the battery the computer booted up and has shown 0% to 1% of charge, I thought that the battery is discharged and left computer to charge for 4-5 hours.
After that I opened the computer and was surprised to see that the charge remained the same - 0% to 1% (I was regularly checking the computer and throughout the "charging" period the charging indicator was always amber). After plugging the charging cable out computer shuts down immediately and turns automatically on when charging cable is connected back.
I tried to do SMC/NVRAM reset after that, which didn't help. Also I tried to put old battery back (which had 61% charge at the time) and it also stopped charging - charging indicator is amber, but percentage stays the same and Coconut Battery shows "Charging with: 0 Watts". I tried to reset SMC again, but the problem remained. On old battery it doesn't turn off if I disconnect charging cable, but obviously then battery starts discharging and I have no way to charge it up.
Now I'm left with a laptop that doesn't work correctly with both batteries.
Also Coconut Battery screenshot with new battery installed.
Does anyone know how to fix this?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
I would start off doing a SMC reset. Follow this Apple TN: Reset the System Management Controller (SMC) on your Mac.
Coconut is reporting the charger is connected but not charging which could also imply the charging logic is damaged on the logic board. Did you follow proper ESD protection? You might have Zapped something.
해당 답변은 도움이 되었습니까?
점수 2
댓글 2개:
Thanks for the reply, but as I stated in the question I already did SMC reset multiple times. While doing replacement I followed ESD protection.
As you lumped it together with NVRAM just wanted to be sure you had.
댓글 달기
귀하의 답변을 추가하세요
Juri 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 132
