An 18V battery powered angle grinder first introduced by RYOBI in 2014. It was released as part of RYOBI's ONE+ system of tools that all operate on the same battery pack.
이 토론글을 스크롤하여 댓글을 달 적절한 위치를 찾으세요. 그런 다음 "이 게시글에 댓글 달기"를 클릭하여 댓글을 이동하세요.
댓글 1개:
If you run the motor and turn the tool upside down, or possibly with the tool head pointing down, does it make a grinding noise?
If I had a tool that had a working motor, but wasn't spinning, I would first look at the motor shaft connection to the transmission gears, and transmission gears themselves.
Geoff Ice 의
