How can I boost my signal for my fire tv stick
i live in a mobile home and i use a friends wifi but i dont think his wifi signal is strong enough to run my fire tv stick from across the street can i fix this problem with a wifi antanna if so what is the best antanna to use
좋은 질문 입니까?
댓글 3개
my firestick cable keep stopping. I could be watching a movie then this little circle shows up 1 2 3 it stays on three for about 2 minutes then the movie comes back on. Shortly after that the little circle comes back on again this time it stays on that Circle for about 5 minutes then the movie comes back on this happens all the time. Note I have Wi-Fi in my home do you think buying this piece from Amazon will help
Gxx24u123 의
no, this item will not help you, the circle you see spinning is when the device is working or waiting... being that you are using a firestick.. I would think it is buffering the movie/stream or whatever you are watching. I would suggest looking at your internet speed or modem/router for issues there.
Richard Simpson 의
I have a similar issue with watching programs using my firestick. My speed is about 240 at the TV but it falls to about 40 when I complete a speedtest for my firestick. I changed my modem/router which now has a speed of 600+ at the router. The 240 speed at the TV is more than enough but the firestick is not picling up this speed. I even installed a connector which improved the speed to the TV but not to the firestick. Is there something wrong with the firststick itself. I have a HD $K firestick.
Hiram Sem 의
