Blade in the cup is loose
the blade in the cup is loose and the liquid comes out the bottom how can I repair this.?
좋은 질문입니까?
좋은 질문입니까?
I had the exact same problem with mine as did my neighbor. Its caused from overloading the bullet with tough material. You simply need to warranty the bottom blade or replace it. The Bullet usually comes with a couple different blades. If you use the other blade you probably see different results i would bet. And i would also bet that you smell a rubbering burning smell when you do use the problematic blade right?
이 답변이 도움이 되었나요?
지난 24시간: 2
지난 7일: 8
지난 30일: 34
전체 시간: 7,452
