iPhone 6s Plus won't turn on after device abuse
I was wondering if someone could assist me in trying to repair/salvage this iPhone 6s Plus that I was given to by a friend. According to him, he had repeatedly abused his device by smashing the phone's backside onto hard surfaces causing the phone to lose accelerometer & gyroscope functionality, and eventually causing it die.
The phone no longer turns on even with a hard reset, is no longer recognised by my computer and will not charge. I don't know exactly what has happened to the internals as I do not yet have the tools to take a look inside but I suspect that it has got something to do with the battery - i.e. battery dying, flex cables being disconnected from the logic board.
I also suspect that some of the internal circuitry has been damaged from repeat smashes resulting in components such as the logic board to fracture or crack. I forget to mention that the phone is also slightly warped and bent backwards, away from the display.
I would really appreciate it if someone could share their knowledge so I can at least get this phone back up and running. Ideally, I would also like to repair the accelerometer and gyroscope, but I think these involve operations requiring a high level of soldering which is arguably beyond my current capabilities. I may also look into replacing the back housing just to make the phone looking new again.
좋은 질문 입니까?
댓글 1개
Probably lots of loose screws from what you've said.
Ben 의
