주요 콘텐츠로 건너뛰기
Nintendo's first 3DS handheld device released February 2011, identified by model number CTR-001.
456 질문 전체 보기
Why will My 3ds not charge or turn on at all
Hi,
My 3ds will not charge or turn on
Here are the symptoms
There is no popping or snapping noise
The battery is healthy and has 3.06 volts on it so the battery should be fine.
The system has not been water damaged or near moisture of any sort
I opened up the backplate and removed the bottom half of the console casing (stripping some screws and possibly damaging the shell in the process, but thats not my concern)
and I checked the continuity of the leads. The negative lead from the chargepads to the battery contacts check out , however the positive lead does not.
( I have a feeling the problem is the positive lead, but I just want to be sure)
I have looked up online for a solution and I just think that the charge port just needs to be re-soldered onto the motherboard.
thank you for answering my question in advance
-Antonio77
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
Maybe you should replace the battery?
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
no, the battery is healthy. The battery works in my friends system
댓글 달기
Hi have you checked the fuses? Think the 3ds has 2 fuses, one near the charging port and one on the power board.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Antonio 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 2
전체 시간: 86
