주요 콘텐츠로 건너뛰기
Guides and repair information for 49cc gas-powered scooters.
just will not start without a jump starter
replaced battery,new start,changedspark plug new coil drive belt replace cleaned filter changed oil last timeit started needed to use a jump starter drove it like that for months
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
선택된 해법
So no kick start huh? Sounds like your battery isn't putting off enough cranking amps so you need to connect it to an external power supply to start the scooter (if I understand correctly). Try replacing the battery (again) with a high quality brand such as interstate. Also you may want to check your air to fuel ratio on your carburetor. Hope that helps.
"The 'Net is a waste of time, and that's exactly what's right about it." William Gibson.
이 답변이 도움이 되었나요?
점수 3
댓글 달기
답변을 추가하세요
rchabonian 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 6
전체 시간: 2,876
