주요 콘텐츠로 건너뛰기
15.6" Windows 8.1 Laptop manufactured by Toshiba in 2014.
10 질문 전체 보기
Insert proper boot can't reset default will not load from hdd,odd,usb,
Will not load from any source.eth,hdd,odd,sub. Keeps saying insert boot device press any key or restart and choose boot device! Can't remember bios master and will mother me choose restore default
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 2
댓글 달기
답변 2개
가장 유용한 답변
brian hunt you must get into the BIOS to change the boot order for your device. This "insert boot device " usually means it cannot read your HDD where the OS is stored. If you do not have the password, you can check on here and see if that applies to your computer. If not, you will have to contact Toshiba (any phone number will depend on where you live) and see if they can help you with that.
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
Hey, folks. I am Arthur, I had also faced this kind of issue on my device. To resolve these issues I studied many blogs and articles on this subject. Now I can fix this kind of issue. I can't post the full solution of the Toshiba Satellite Master BIOS Password. If you are undergoing this kind of problems you can communicate Toshiba support freely to get cooperation. A certified craftsman will help you out. I am sharing a link of one of those blogs, just read the blog and learn the procedure to determine this issue.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
brian hunt 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 2
전체 시간: 173
