주요 콘텐츠로 건너뛰기
Repair guides and support for tablets manufactured by Azend/Envizen.
Cant get tablet to turn on
I turned my tablet on to connect my wifi then turned it back off to make sure it saved the wifi and now it will only turn on to the main envizen digital screen
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 달기
답변 4개
가장 유용한 답변
sjwilkinson86 , Ensure charger is working and device is charged. There a few reset procedures you can try.
Try this reset procedure 1st., Press and hold the power button for exactly 35 seconds then release, wait 2 minutes, then power on device. May have to repeat this 3x, if does not work try procedure #2.
2nd reset procedure: Plug the Tablet into the charger for 5-10 minutes, (while still plugged in) press and hold power button for 35 seconds, wait for up to 3 minutes for the Tablet to reboot.
Still not power up properly, find the reset hole in the side of the device and use a straightened paper clip to press the reset button.
Still not working return for warranty as defective, if warranty still valid. Good luck.
이 답변이 도움이 되었나요?
점수 3
댓글 달기
Contact info for the Envizen Digital EVT10Q (for all who are interested for this tablet)
U.S.A.
ZIOTECH CORP
13517 BENSON AVE
CHICO,CA 91710
TEL-1-866-709-1999
This is a repair center for this tablet. I hope this helps.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Give me instructions to reset tablet. Forgot the pattern
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Estoy recibiendo mensaje que dice app permition management y no me deja entrar en mi tableta. Por favor si me puedes ayudar
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
sjwilkinson86 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 3
지난 30일: 8
전체 시간: 1,683
