주요 콘텐츠로 건너뛰기
27" 화면 2560 x 1440 픽셀 해상도 Thunderbolt 및 MagSafe 케이블 부착물
160 질문 전체 보기
Brightness can be set only on low setting
Hello community,
I have a Thunderbolt Display which was used with my Macbook Pro (Windows 8.1 via Boot Camp). 2 days ago it made a clicking sound and the picture went dark on the Windows OS. After that I took the Monitor home and tested it with my Macbook Pro at home (OS Sierra). I can set the brightness in the Apple OS but only from Dark - 1 -2 Points (using ctrl + f2), when I go on the next one (Number 3) it doesn´t get brighter and the picture starts to flicker. All the next brightness Settings do not change the flickering or get brighter.
Installed the Firmware 1.2 - didn´t do any change.
Maybe someone had a similar issue...
Thanks in advance!
Nejc
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 2개
I lifted the LCD Pannel, checked all the Connections (couldn´t see any problems). Left it alone for 3 days. After that it started working as usual again....
Did the issue ever come back?
댓글 달기
답변 1개
선택된 답변
It sounds like something went screwy with the power regulator that feeds the backlight.
해당 답변은 도움이 되었습니까?
점수 0
댓글 3개:
Well after I unplugged the Monitor it showed the same symptoms... Can I somehow repair the power regulator for the backlight? Or do I have to change it?
Have a similar issue. If display brightness is set to above 70% after several minutes of use the screen goes black. Works totally fine if the brightness is below 70% (approximately). Replaced the power supply and tried a separate TB cable neither helped resolve the issue.
Hi Guys, having similar Issue. TBD flashing sometimes and later blackouts. When i lower the brightness it seems to work ok. Did you find out anything about the hardware or software driven reason of this problem? cheers!
댓글 달기
귀하의 답변을 추가하세요
Nejc Sitar 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 3
전체 시간: 586
