Can it be hooked to a hard drive
I want to hook a external hard drive to the next book will it let me do this
좋은 질문 입니까?
좋은 질문 입니까?
James --
There are a couple of issues here: connectivity & power.
The Nextbook needs to provide enough power for whatever device you connect. Simplest test for this is to use a USB flash drive since they require little power. For a larger device, be sure the Nextbook is plugged in charging mode to provide the most power.
Next: What is the Operating System of your Nextbook?
Good luck,
Russ
해당 답변은 도움이 되었습니까?
24 시간 전: 0
7일 전: 2
30일 전: 2
전체 시간: 1,648
댓글 2개
Best way to find out is to just try it. Connect a USB drive, power up and see if it recognizes it.
Russ Walden 의
Has anyone replaced the internal 32GB with more storage,or is it hardwired?
Igor Schmidlapp 의
