주요 콘텐츠로 건너뛰기
Apple iPhone 5s는 2013년 9월 10일에 발표되었습니다. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 16, 32, 또는 64GB / 은색, 금색 및 스페이스 그레이.
3530 질문 전체 보기
Vibration doesn't work when the phone is completely assembled.
Hi everybody. I recently changed the LCD screen of my iPhone 5s (third party, works perfectly). When I reassembled the phone, I realized that the vibration was not working. I opened the device again, and realized that the vibration works perfectly as long as the LCD is not completely inserted. As soon as I press the LCD to make it fit into the back case, the vibration stops working. I think it is some kind of contact's fault. Any suggestions? Thanks in advance.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
선택된 답변
You probably have some contact or friction between the screen assembly, specifically the camera and sensor housing, and the vibrator. It could be physically obstructing it or causing a bad electrical contact.
Go back though this guide to double check that you have everything properly installed.
해당 답변은 도움이 되었습니까?
점수 3
댓글 2개:
Fixed! It was indeed a mechanical issue, a little part of metal of the front camera housing was pushing on the vibrator. Thanks a lot!
My pleasure!
댓글 달기
Hi
This is cause of display thickness plz try with another display or check something near vibrator might struck
Hope It Works
Thanks
Varun
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
ignitus 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 1
전체 시간: 70
