주요 콘텐츠로 건너뛰기
A line of external hard drives by Western Digital, styled after hardbound books. Available in various editions from Essential, to Premium to World Edition.
My harddrive fell off a table and is now buzzing...
My harddrive fell and is now making a buzzing sound.......when I plug it into the computer nothing pops up anymore. Is it broken? Or has the disk just maybe gotten off track? Where can I take it to hopefully get it repaired?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 4개
Thank you. My entire business aka my LIFE is on that harddrive so yes I'll take your advice and send it to professionals. ...will they write the salvageable data onto a USB for me or something?
I'm pretty sure that's what they would do, whether they would have you bring your own or charge you for one I guess depends on the place. I would recommend looking to see if you have any local repair shops that could diagnose/fix it for you before you'd ship it somewhere. I know this probably wasn't the news you wanted to hear but hard drives are fragile tools. :/
Your Drive got physical Problem Read/Write Heads failure dont connect power again it might scratch platters visit any Professional Data Recovery firm if your data is important they might Recover Data in Basic cost ....
http://lifeguarddatarecovery.com/data-re...
Your Drive has physically damage. Read/Write Heads failure dont connect power again it might scratch platters. You can visit any Professional Data Recovery firm if your data is important they might Recover Data in Basic cost might Recover Data in affordable cost
https://lifeguarddatarecovery.com/ or in India https://lifeguarddatarecovery.in
댓글 달기
답변 2개
선택된 해법
Any drop or knock can cause a head crash in your external hard drive, which means the read/write head of the external hard drive came in contact with the platters. If a hard drive is dropped and it isn’t working anymore, it is likely that the platters, arm or render head of the hard drive were damaged or misaligned from the impact. If the render head is trying to locate the data that it is searching for on the platters and it cannot find it, the arm will move back and forth across the platters several times. The head is attached to an arm that hits a stop every time it goes back and forth, which makes the clicking noise. You might be able to try a few software programs but they won't help much besides logical issues. Software really only addresses issues with reformatting, but even then, resorting to software may make matters worse. Your best bet is that if you truly have stuff of value on there is to send it to professionals. Otherwise, I have heard of a few companies that would send you a replacement but that obviously won't save your data.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
Your drives requires platter cleaning and fixing through physical data recovery. Your Drive got physical Problem Read/Write Heads failure dont connect power again it might scratch platters visit any Professional Data Recovery firm if your data is important they might Recover Data in Basic cost ....
++http://lifeguarddatarecovery.in++
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Keke T 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 4
지난 7일: 14
지난 30일: 69
전체 시간: 11,602
