주요 콘텐츠로 건너뛰기
모델 M2453 또는 M6411 / 300, 366, 또는 466 MHz G3 프로세서
64 질문 전체 보기
Is this iBook capable of running on 10.3?
I found this ibook at the thrift store for 20 dollars. So I bought it a power cord, and tried it out. This computer works FLAWLESSLY compared to the other one I bought "refurbished" (A1040). Even the GPU is good, and it has never frozen once. But it runs on Mac OS 9.2. Which I cannot even use the internet on. I am planning on downgrading my other ibook because of the problems I was having on it.. But I wanted to know if I can use the Panther 10.3 discs on this one to upgrade it as well? Is there enough hard disk space to support that version? I know I can always upgrade the RAM.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 1개
Mine is the M2453, if that helps.
댓글 달기
답변 1개
가장 유용한 답변
Hi Sarah, According to Mactracker your unit is good up to 10.3.9. I would max the ram. Good luck.
해당 답변은 도움이 되었습니까?
점수 1
댓글 4개:
If the 10.3 installation disks are gray, they are for that specific machine and will not work on your Clamshell.
Ok. The discs are black with an X on them. I am currently downgrading my white ibook. At first I was confused about the whole select volume part, but I just went into options and selected to overwrite and not save archives. Now for the clamshell, when I put the disc in, it showed different pictures than it does in the book, and on this ibook, but it seems like it was asking for the same prompts? I didn't go ahead with it just to be sure.
I am quite amazed and happy to say that it hasn't froze once through the whole process..
I'm happy for your success--good work.
댓글 달기
귀하의 답변을 추가하세요
Sarah 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 3
전체 시간: 635
