주요 콘텐츠로 건너뛰기
The GoPro Hero5 Black is an HD waterproof action camera released by GoPro in October of 2016. The 4k resolution video camera has voice control, a touch screen display, and built in WiFi.
85 질문 전체 보기
The LCD screen has a hairline fracture
I purchased my GoPro about a month ago - and the GoPro Hero LCD screen has a hairline fracture! I just took it out the case after using it - and the crack appeared. I did not drop of doing anything that would impact the camera. Has anyone else had this issue? and or know how to repair it or warranty the camera?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 2
댓글 1개
Is it still waterproof
댓글 달기
답변 3개
가장 유용한 답변
Are you sure it's cracked? And is everything on the LCD still visible?
해당 답변은 도움이 되었습니까?
점수 1
댓글 2개:
100% cracked. LCD still works fine
@jezza even if it is cracked, if it is visible I wouldn't worry about it. But if it develops black spots then replace it. Even if you replace it it would probably still be pretty expensive as the device is still new.
댓글 달기
Where could i go to get it replaced?
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
I noticed mine was cracked this evening too. Hasn't been dropped or abused in any way. I think this is a protective glass over the LCD screen, since the LCD screen still seems to work fine.
Would be interested know how I go about getting it fixed.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Jezza 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 9
전체 시간: 4,258
