주요 콘텐츠로 건너뛰기
2016년 3월 Samsung에서 출시되었습니다. 모델 SM-G930V.
425 질문 전체 보기
Must I replace cracked back when replacing camera?
I've actually got a couple of questions for this repair, but the main one being whether the glass back of my S7 will crumble if it take it off to replace the camera? Thus, will I need to replace the back glass as well? My camera got rekt by water damage due to the cracked glass, so will replacing the back restore water resistance to prevent further damage?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
Its best to assume that it will shatter further when removed, you need to use a reasonable amount of force (and plenty of heat) removing the back. I have had broken S7 backs come off still in one piece but also have had them break further.
As for water resistance a whole back will be more resistant than a broken one but even if you have can get some of the original adhesive you'll never be able to replicate the factory conditions that it was originally sealed under so you'll never be able to achieve the same water resistance so it would best to operate under the assumption that it is no longer waterproof.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
Alec 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 3
7일 전: 3
30일 전: 3
전체 시간: 139
