주요 콘텐츠로 건너뛰기
2014년 9월 19일에 출시된 이 4.7” 스크린 iPhone은 iPhone 6 Plus의 작은 버전입니다. 모델 번호 A1549, A1586 및 A1589로 식별됩니다.
4994 질문 전체 보기
iPhone is not booting. Screen flickers
Hi.
Have a problem with an iPhone. It won´t boot. When it tries to boot the screen suddenly flickers in many colors and then reboot.. It does this two times, and after that it´s not possible to turn it on before the battery is disconnected and reconnected.
I have tried several (original) screens and batteries. Anyone know what might cause this problem?
Here is a video showing the problem:
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
가장 유용한 답변
What model iPhone? The 5 and 6 gens can be damaged by installing the screws in the wrong place causing damage to the motherboard. You would need a microscope to see it. You can search "Long screw damage" or "blue screen of death" (BSOD) to see more symptoms and causes. The only repair for this is highly skilled trace damage micro soldering which very few repair shops can perform.
해당 답변은 도움이 되었습니까?
점수 3
댓글 1개:
I've put it under a microscope today, and there is no damage on the motherboard (where the screws are)
댓글 달기
It looks like you might have damaged the logic board try checking the logic board to see if possibly chipped any parts.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
alex 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 1
전체 시간: 519
