주요 콘텐츠로 건너뛰기
Samsung의 5-세대 Android-기반 Galaxy 스마트폰은 2014년 4월 11일에 출시되었습니다. 이 휴대폰은 지문 스캐너, 최신 카메라, 대형 화면 및 방수 기능이 개선되었습니다. 네 가지 색상으로 제공됩니다; 검정, 파랑, 흰색 및 구리.
Home button not working after USB Charge Port Replacement
My friend has 2 Galaxy S5 phones. One is a G900A and the other a G900T. He replaced the USB Charge port on both. On a GS5, the charge port is on a daughter board which also houses the home button and soft buttons. For some reason the soft buttons work but on both the home button no longer works. Even the original ones he had don't work anymore. I took a look at it, and I couldn't see anything wrong. I even double checked the iFixit guides. We also had the seller of the parts resend replacements and bought another from a different source. All have the same problem. Does anyone have any idea?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 6개:
@avanteguarde
I've noticed you've been inactive the last few days. Something wrong?
I will find you. I will fix you.
Ifixit play on Leon Neeson
Samsung Galaxy S5 Teardown
See steps 6 and 12 for insight on the home button and its cable. That's the best I've got to offer.
@pccheese, Internet problem. Windows 10 updates will swallow your bandwidth whole!
Are you on DSL? We've got 6 windows 10 PCs and we never have a bandwidth problem. You've been out for days!
Yeah, DSL. Try running 10 Windows devices on that! Especially with the creators update coming.
댓글 1개 더보기
댓글 달기
답변 1개
The home button on the galaxy s5 connects directly to the MB if I remember correctly. Double check the integrity of the board side (female) connector; if the home button got pulled out without being properly unplugged it could be causing the issue.
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
@xela, no, the home button is part of the charge port daughterboard along with the 2 soft buttons. The soft buttons work, but the home button does not. The chargeport has been change 2-3 times from different sources, but the home button still does not work.
댓글 달기
답변을 추가하세요
S W 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 8
전체 시간: 849
