주요 콘텐츠로 건너뛰기
2016년 3월 Samsung에서 출시되었습니다. 모델 SM-G930V.
425 질문 전체 보기
galaxy s7 waterproof when l fixed
hi guys
I have a some problem that my galaxy s7 broken the back screen so I tryed to self repaired and i fixed
so can s7 still be waterproof?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 3개
가장 유용한 답변
If you had access to the same adhesive Samsung uses and followed the exact same procedure they use for sealing the device, then it should have the same amount of water resistance. However I am assuming you don't have access to these as Samsung hasn't released them to the public so it would be best to assume the device is not as water resistant lest you get a rather nasty surprise.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
You will likely lose some of the water resistance.
The phone was never water proof.
It can handle the rain, but you can't take it swimming.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
The phone can't be guaranteed waterproof after repair.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
남김홍찬 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 876
