주요 콘텐츠로 건너뛰기
Apple의 최신 소비자용 노트북 제품군인 MacBook Air 수리 가이드입니다.
4818 질문 전체 보기
My computer is typing the letter z constantly
my computer is typing the letter z constantly. I can barzely type this letter!z I took the key off, nothing is stuck. I reset the czomputer. It was an intermittent przoblem, but now seems permanent. Also, the letter z does not type when I press the keyz
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 4
댓글 2개
I have the same issue with z key. What was the problem with yours? Did you get fixed? How much was it to fix. Please share any info you have. Thanks.
i too havze this probzlemz.z funznyz is that it onzly types this letter after czertainz other letters: mz nz bz vz cz xz andz other letters are finez
댓글 달기
답변 4개
가장 유용한 답변
It definitely sounds like the circuits responsible for the z key are started to ground, causing it to be seen as permanently pressed down by the system. This could either be a fault in the keyboard (which is most likely), or could be a motherboard issue. I would first try and clean out the connector - if it's still pressed down, then run the computer with the keyboard unplugged, and see if the issue persists. If yes, then it is a motherboard issue. If no, then it is an issue with the keyboard.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
Try removing the back of the Macbook and disconnecting the keyboard from the logic board. Then connect a removable keyboard via usb. If the problem no longer occurs then you need to replace the keyboard of the macbook.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
I plugged in an external keyboard and it worked then tried laptop keyboard and it works now too!
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
I have the same problem on my macbook air 2015 model. How to fix it pleasee help my Mac condition is really nice idk why it is happening ?
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Andrea 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 3
7일 전: 13
30일 전: 62
전체 시간: 10,942
