주요 콘텐츠로 건너뛰기
Apple iPhone 5s는 2013년 9월 10일에 발표되었습니다. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 16, 32, 또는 64GB / 은색, 금색 및 스페이스 그레이.
3530 질문 전체 보기
Power button stuck after rear case replacement
I'm changing iPhone 5S rear case, but for some reason power button does not seat properly in its place during assemble. It's stuck and I can't push it. Button doesn't move at all. I have watched it very closely so that everything is in the right position, and I just can't find what is wrong.
Hinge of the power button bracket is on its place, orientation of the button is correct, I have moved this little round metal plate from the old button to the new one and also the little black dot is still on its place on the top of the cable.
I tried to search this with Google and from this web page but couldn't find anything. Does anyone have had this same problem? This is already the second time I have encountered this problem. Is there some easy trick to get this fixed or what? I just can't figure out why this power button gets stuck every time I try to replace it.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 2
댓글 달기
답변 2개
선택된 답변
Finally I solved the problem. I wonder why this answer couldn't be found anywhere on the internet. Maybe someone should update iPhone 5S power button guide and mention this.
I had to tear down my another iPhone 5S to compare these power buttons, but finally I solved it. If you are moving metal bar from the old power button to the new one, it is not indifferent which way you put it. This metal bar is not symmetric, as I assumed, so if you put it wrong way, power button doesn't fit into its place correctly. Then it gets jammed when you assemble phone.
I have tried to draw correct position of metal bar to this picture. Notice those curves!!
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
Hi There,
When you tear down the phone always see where each components belong. I assume the Power button is not fitted in its origin al position. Try screwing the power button screw on the Frame. I guess that might help.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Asko Pesola 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 475
