주요 콘텐츠로 건너뛰기
MacBook Pro 13" Retina Display, 모델 A1502의 2015년 3월 업데이트는 5세대 Intel Core i5 및 i7 프로세서를 포함하며 Force Touch 트랙 패드를 소개합니다.
20 질문 전체 보기
It wont turn on
I have a macbook pro 2015 I got it used from liquidation site i bought it like that since and a student I cant affort to buy a newer one and my hope is fix it , they took the ssd out but the problem is that the macbook pro does not turn on I albready open the laptop and it looks ok to me .
you guys think by not having the SSD it is why is dead
regards
David
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 1개:
If you disconnect the battery, unplug the charger, then plug it back in, does the fan spin at all?
댓글 달기
답변 1개
Are you getting indicator lights? Does it charge? Any signs of life when you press the power button?
If you get nothing at all, it's a good idea to discharge the power circuit. Remove the battery and AC cord. Hold down the power button for 10-30 seconds. Without letting go, reattach the AC cord and continue holding power for another 10-30 seconds. Release the button and try turning it on normally.
(On Windows machines, this is also a good way to clear the CMOS on some machines.)
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
It has a amber light when I connect and the charger and by pressing Shift, Control, and Option keys on the left side and the power button, all at the same time I can see it becomes green and flashes 3 times and after that it goes back to amber but it is completetly dead :(
댓글 달기
답변을 추가하세요
davidmiranda33 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 0
전체 시간: 807
