주요 콘텐츠로 건너뛰기
4 inch display / Available in a variety of colors / Released in 3 different models / 16, 32, or 64 GB capacity
331 질문 전체 보기
iPod won't boot pass the apple logo and home button is broken, help?
When I'm trying to open my iPod touch 5th gen (which is fully powered off), it starts booting but even if its booting my device shut itself down after a minute. During that time, we only see the Apple logo. With this, my home button is broken. Anyone can help me fix this issue with my beloved phone ???
P.S : My battery has a very low lifetime due to longtime use. Also, when i put my iPod on the charge it opens on the apple logo then it crashes and it doesn't try it again.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
Bonjour Jérémy. My initial suspicion would be that you have a bad battery. If it can no longer hold a charge, then it will attempt to boot and then fail.
You could possibly have a problem with the charging circuit on the logic board but the battery is the obvious thing to try first. Also insure that you are using genuine cables and chargers as they can cause damage to the charging circuit.
You could buy a battery here.
iPod touch (5th Gen) Battery 이미지
상품
$9.99
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
귀하의 답변을 추가하세요
Jérémy Langevin 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 216
