주요 콘텐츠로 건너뛰기
2세대 iPhone. Model A1241 / 8 또는 16GB 용량 / 검정 또는 흰색 플라스틱 뒷면. 첫 번째 iPhone보다 수리는 더 간단하며 스크루드라이버, 비집는 도구 그리고 흡입 도구가 필요합니다.
1158 질문 전체 보기
질문 마감됨
Replaced Battery but it will not charge
Hi -
I just replaced the battery with a new one from ifixit.com. I turned it on and everything works. I immediately plugged it in to get a full charge on the new battery but it doesn't seem to charge.The lightning bolt comes up but then it goes to the plug icon which usually means fully charged. I unplug it to see if it is and its stuck at half way. Do I have a defective battery or did I do something wrong? I left int plugged in for 2 hours and it hasn't passed the middle charge yet.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
I have seen this issue before, for me it was a defective battery. I just replaced the battery with another new one and everything worked fine. Good Luck.
"No man has a good enough memory to make a successful liar." -Abraham Lincoln .
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 1
전체 시간: 845
