주요 콘텐츠로 건너뛰기
Model No. A1367 / 8, 16, 32, or 64 GB capacity
915 질문 전체 보기
Not turning on, Not recognized on computer or iTunes.
Hi guys,
I have not been able to get my older iPod touch going in a long time! I'm pretty good at troubleshooting so the obvious I've already tried. I am confident that physically it is in great condition and this is a software issue. When I bought it within a few months the 5th GEN come out and I didn't update the new iTunes right away. When I tried later on it kept failing so I got frustrated and it sat. Anyway, since then I've spent hours looking up how. So:
- The screen is completely black. Including plugged into the wall, the computer or holding power button/ home combos.
-Is not recognized by the computer
-Is not recognized in iTunes.
-No Apple logo
-No iTunes logo
USB fine. Not broken, cracked, or damaged in anyway.
I understand it is older and will have limits but I bought it so I'd like to use it haha..considering .
I'll give any advice a shot and update
Thank You!
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 3개
Not knowing the circumstances prior to failure... If the unit has not been used for an extended period the battery will probably need to be replaced and is likely the problem to begin with. If the batteries condition drops below par it will not charge, and the for the layman, unit will not turn on without a battery with sufficient voltage, plugged in or not.
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
check my additional answer below
댓글 달기
Try to reboot it.
Hold both the power and home buttons until the apple logo appears.
It often helps
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
I built this just now from known working motherboard and tested battery before install.... dead as a door nail, including taking voltage reading after battery attached to the motherboard and it read 0v. Disconnect the battery, checking with the voltmeter, 3.84v... Remove the connection to charging port ribbon cable as you can see in the photo, recheck battery after reattaching it to the motherboard… PRESTO! I either had a bad connection to the ribbon cable, or bad ribbon cable, or both. Again the battery read zero absolute zero(with it fully charged) until I disconnected the ribbon cable and the voltage back. Anyway, food for thought.
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
for clarification "dead as door nail" was condition after initial assembly,
댓글 달기
귀하의 답변을 추가하세요
Ash123 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 4
전체 시간: 139
