주요 콘텐츠로 건너뛰기
Sony Xperia M4 aqua was released 2015, June. With a Size of 5.0 inches, it was operated in Android OS, v5.0.1. Sony Xperia m4 Aqua has internal of both 8 GB, 2 GB RAM/ 16 GB (E2306) And it has 13 MP Primary Camera and a 5MP Secondary Camera. This phone has a non-removable Li-Ion 2400 mAh battery.
37 질문 전체 보기
I have a Black screen but the phone is working fine
Hi, I've recently been experiencing a black screen problem with my phone. It's able to receive calls and messages and such and the screen is responsive. However the screen is black and so I cannot see what I'm doing.
So I wanted to ask is this due to the back light ? Or would I need to replace the LCD to fix this?
Any answers given would be great !
Thanks
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 3개
What happen? Have you dropped it?
If you can hear the phone working ... calling, receiving text messages, etc most likely is a LCD problem.
If you dismantle it, you should check the LCD connection first, maybe use isopropyl alcohol to clean the connection a little bit, only then I'll say for sure LCD is faulty.
Thank you for replying, and yes I dropped it but it wasn't serious
Hi,
I have a problem of blue screen error phone got hanging restart
again and again
댓글 달기
답변 1개
선택된 답변
This is most likely a damaged LCD.
The way to tell if it's the backlight is shine a flashlight on the screen when you think it's on and see if you can see faint images. If you don't see anything, it's the LCD
해당 답변은 도움이 되었습니까?
점수 0
댓글 6개:
Yes when I shine a flashlight at it I can see my message notifications, so would this be a problem with the back light ?
Ok, so first I would use the flashlight to test if the touch works, if it does then you can unlock the phone to back it up. Then I would try and track down a repair shop that does logic board repairs. If they determine it's a screen issue then it looks like you can get replacement screens online for around $50
Thank you so much for your help ! I'll try and have a look and comment if I get any success. Also it's too difficult for me to unlock my phone and back it up as it's pretty dark. But if I get a logic board repair will this affect my data/ saved information on my phone ?
Also would I have to replace the screen or the LCD ?
The "screen" is generally a combination LCD, glass panel, back light and digitizer all in one. Theoretically you shouldn't lose any data on either repair, but it's always good to have it backed up just in case something happens.
So if I purchased this:
http://www.witrigs.com/oem-lcd-with-digi...
It should hopefully resolve this problem ?
And many thanks for taking your time to answer my questions ! I'm really grateful
댓글 1개 더보기
댓글 달기
귀하의 답변을 추가하세요
Christina 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 4
7일 전: 11
30일 전: 21
전체 시간: 6,499
