주요 콘텐츠로 건너뛰기
Apple iPhone 5c는 2013년 9월 10일에 발표되었습니다. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 8, 16, 32GB / 흰색, 분홍색, 노란색, 파란색 및 녹색으로 제공하였습니다.
earpiece not working but in different phone is working
Hi everyone
I have problem with one iPhone 5C, the earpiece won't work but if you press on it works.
I replace the screen with new earpiece and new proximity flex that are working in different device and still it doesn't work when I place back in the phone.
Anyone had this issue before?
Thank you for your help
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 2개
선택된 해법
Could it be the screen frame? I've seen screen frames where they have caused horrible installation of the metal plate and two screws for the earpiece / front camera assembly.
이 답변이 도움이 되었나요?
점수 3
댓글 1개:
Hi Ben,
I have tried with numerous screens and is still not working.
I have put full assembly screen with all installed that work in different phone and when I put it in the one with the issue doesn't want to work.
So I guess it is not the screen it is motherboard issue but I don't know where to look and what to do.
If you have any ideas I will appreciate the help.
댓글 달기
Probably you have damaged the J1 connector or a part near this connector. See the schematic, check pins 24,26,28 and parts that connect to this pins.
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
Thank you very much for your answer.
The phone came with this problem and I just couldn't fix it :)
I will check this pins and see if any of them are damaged.
댓글 달기
답변을 추가하세요
Mimi 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 2
전체 시간: 99
