Why is my Jbl charge not charging anymore
Tried charging it with several chargers but it didn't work.
좋은 질문입니까?
좋은 질문입니까?
2 Possibilities are
1. You broke the tiny board in the port. Check the port, if you don't see a tiny little probably black think inside of it then you broke it.
2. You broke the connector of the board. Open the device and look where the port is. Does it look like it's lifting off the board? Is one or more of the legs not attached?
If the first one is the case you need to either get a new speaker, replace the port or take it to someone who can replace the port
If the second one is the case, replace the port or take it to someone who can.
Replacing these ports requires a soldering iron with a small tip, steady hand and a good understanding of how to solder.
If you know how to solder another option is to directly attach a cable in which can't be removed. I don't recommend it however because I tried this and it didn't work for me.
I hope all these words help! Good luck on fixing it!
이 답변이 도움이 되었나요?
I got same pro wt charge 2 gonna give it a go , ILLLBBACK! thanks ✌️
Hi, how did it go. I have made small PCBs wit soldered micro USB, so I just soldered the cables. (If it is Charge2, not Charge 2+) as minimum order was 5 PCBs, I ended up with 125 pieces. 124 left for whoever needs - free.
지난 24시간: 0
지난 7일: 0
지난 30일: 10
전체 시간: 31,792
댓글 1개
how do you open it up
Ken Calder 의
