Bench Mark TEST review
https://browser.geekbench.com/v4/cpu/198...
https://browser.geekbench.com/v4/compute...
does this look all good????
좋은 질문 입니까?
좋은 질문 입니까?
No it does not look good. It's running at least than half of what it should.
See the standard Geekbench scores here:
Geekbench 2 (32): 6690 Geekbench 2 (64): 7323
Geekbench 3 (32): 2530 Geekbench 3 (32): 5106
Geekbench 3 (64): 2781 Geekbench 3 (64): 5689
해당 답변은 도움이 되었습니까?
What would cause that??? It's new with a 500gb SSD and two crucial 8gb ram cards. It also has only 70gb taken on the drive
I would replace the HD SATA cable. These cables have wear issues which can impact performance. Here's the IFIXIT guide to replace it: MacBook Pro 13" Unibody Mid 2012 Hard Drive Cable Replacement and the cable you need: MacBook Pro 13" Unibody (Mid 2012) Hard Drive Cable
I called Apple and I'm gonna have them check it out Monday. Computer speed feels fine. I used geek bench v4 to run the test
24 시간 전: 0
7일 전: 2
30일 전: 4
전체 시간: 126
댓글 6개
What do you mean by good here? Good is somewhat subjective depending on how you are looking at this.
What are you comparing it to and what is the reason for the concern?
Dan 의
Is it normal speed for a stock CPU a Samsung ego 500gb SSD and curicial 16 gb ram upgrade two 8 gb ram cards?
Collin.nesbitt@gmail.com 의
What Evo? 960, 850, 950, etc.
George A. 의
Did you try another benchmark service? There may be something wrong with that one. Does you computer actually feel slow?
George A. 의
No it's pretty fast I was just wondering if it's ok cause the numbers EVO 850
댓글 1개 더보기
