How do I find apps I have downloaded?
When i download a Google app, "Installed" appears but I can't find it.
좋은 질문 입니까?
좋은 질문 입니까?
We can see all the files which you have downloaded in your phone. In Samsung phones or we can say that in all android phone we can find our downloaded files in a folder called 'My Files' , sometimes this folder is in another folder called 'Samsung' located in the app drawer. You can also search your phone via Settings > Application Manager > All Applications
해당 답변은 도움이 되었습니까?
Thank you !!
Very useful answer
I cannot get off this.page on Samsung internet
My files please
1. Tap on "apps" on your screen.
2. Tap on "samsung".
3. Tap on "my files".
4. Tap on "documents"
You ll see all the files you downloaded.
해당 답변은 도움이 되었습니까?
Not getting anything
Sook Dalkie -- Apps folder is not on my screen. Also, nothing comes up when I search my apps. Where do I go now? Thanks in advance.
In most Android phones you can find your files/downloads in a folder called 'My Files' although sometimes this folder is in another folder called 'Samsung' located in the app drawer. You can also search your phone via Settings > Application Manager > All Applications.
해당 답변은 도움이 되었습니까?
Where is the app drawer?? I asked how to find downloads and all replies are too technical. I now have to work out where my app drawer is!!!!!!
The place where you find all apps installed on your Android phone is the Apps drawer. Even though you can find launcher icons (app shortcuts) on the Home screen, the Apps drawer is where you need to go to find everything. To view the Apps drawer, tap the Apps icon on the Home screen.
I also have this problem. It tells me the file is downloaded but I can’t find it anywhere. This is happening to me with images. I set my phone to give a notification which appears at the top left with a download arrow which indicates the file is downloaded.
I tap that to see the file, then use the three “more" dots at the top right and select “open with". I choose to open it with Gallery.
Now the image is in my gallery and I can find it there.
해당 답변은 도움이 되었습니까?
same here!
Yes same on A6 samsung , why !&&* doesnt it just like my old samsung have files then downloads,,,,its that simple or should be ffs
Try looking in “my files”, click My device, then click the android folder, then click the data folder, then click the com.android.chrome folder, then click files folder, then click Download folder. You should find downloaded files there. Try this.
John
해당 답변은 도움이 되었습니까?
I appreciate your help. It works like magic. I have been struggling for months now. Thank you
I don't know yet how to retrieve the downloaded images. I have the same problem. But I do know how to fix it. It put the download folder back into gallery.
Settings, Applications, click on 3 dots right hand corner, App permission, Storage, Samsung Internet.
Give the Internet or Google permission to storage and viola.
Still workingon retrieving the already downloaded pictures….
해당 답변은 도움이 되었습니까?
Have you seen any folders named "Google" or related..?
(Edit:Try looking in the app drawer for a Search option if you dont see a folder.)
해당 답변은 도움이 되었습니까?
Where us the 'App Drawer'??
Swipe up to see all your apps. Locate the app/folder titled “Samsung.” Click on that and an app should be titled “My Files.”
해당 답변은 도움이 되었습니까?
I don't want to post nothing
I don't know if what I downloaded went to android or Samsung
If you install the app directly via Google Play your app will be installed on the device (or SD card or both) and there no APK file remains. If you downloaded APK via a third party web site on the web browser then after installing downloaded APK should remain unless you deleted it manually or via junk cleaning app. It should be on your downloads folder in device storage or SD card, usually in a folder called /Download. Sometimes your downloaded files are sored in a folder called SD card /MyFavorite. Probably users don’t think this as a downloads folder. Instinctively, it looks more like a bookmarks folder but I found my downloaded files automatically saved there while using Android stock browser on Android 5.1 Lollipop. However, I should mention that it is a heavily modded ( which means I have deleted several key google components which could probably be attributed to this strange behaviour) and rooted device. It is not a Samsung device but an Intex device. SO THIS ANSWER PROBABLY DON’T APPLY TO SAMSUNG DEVICES.
P.S.: I am not an expert on this matter.
해당 답변은 도움이 되었습니까?
I couldn't download apps
해당 답변은 도움이 되었습니까?
There can be several reasons that you cannot download apps via Google Play. Some of which are listed below.
1. Network connectivity problems.
2. You are low on storage of which your device should promptly notify you.
3.Your device is enrolled and managed by enterprise android group policy which may probably block your installation in which case you should contact IT division of your employer to obtain neccessary previlages.
4. Google Play Services functionality is impaired.
First try rebooting. If problem persists check whether you have enough storage to install the app you are trying to download. Usually you need slightly more than twice the stated amount of storage mentioned in the Google play on Android Lollipop to install an app. Make sure you have enough storge left on your device and try again to install your app. If problem still prevails then try factory resetting your phone. If all above fails you have to flash firmware on your device. Just search how to do it online.
One massage received about download of hep desk which I want to delete/ remove
24 시간 전: 1
7일 전: 16
30일 전: 51
전체 시간: 166,584
댓글 26개
How do I access recent downloads
Catherine Lockett 의
, do I have to go somewhere to download my stuff like in Google
Robin Brooks 의
I also wish someone would tell us where the app drawer is but I guess it's top secret
odie 의
Can't find myfiles and can't find anything re downloads
Veritas Vincit 의
I can't find my documents nowhere on my phone I have looked everywhere i. Know to look
Jessie Newkirk 의
댓글 21개 더보기
