주요 콘텐츠로 건너뛰기
모델 A1225 / Early 2009 / 2.66, 2.93, 또는 3.06 GHz Core 2 Duo 프로세서
164 질문 전체 보기
iMac is freezing and picture is pixelized
HI,
I have this iMac that freezes after a couple of minutes of operation; the mouse completely freeze and thera are color pixels everywhere random on the screen.
I have teared the system down and changed the thermal paste on the graphic card (nVidia GT130 512Mb), the CPU and the chipset as well.
The system has been cleaned from dust and I've re-imaged the hard drive with a new version of El Captain OS-X.
Can it be a faulty Video Card?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 2개
Try running MRI. There is also a hard drive test that I think Dan mentioned
I have upgraded the hard drive with a brand new Kinsgton SSD 120gb and this problem was there before the upgrade with the other drive..What is MRI ?
댓글 달기
답변 1개
가장 유용한 답변
Did you run any diagnostics? How to use Apple Hardware Test on your Mac.
If you can't get it to come up, are you even able to get the system into Target Disk Mode? Share files between two computers with target disk mode so you can see the FireWire symbol on your screen.
Let us know what you can or can't do here. Good Luck!
Additional reference: Startup key combinations for Mac
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
andre 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 1
전체 시간: 66
