주요 콘텐츠로 건너뛰기
The Chevrolet Cavalier is a compact automobile produced from 1982 to 2005 by General Motors.
139 질문 전체 보기
Gas leaking from engine?
Hey everyone. I had been smelling gas coming from my 2005 cavalier. I just pulled out of my parking spot and noticed a sizable amount of gas on the ground. I haven't popped the hood yet it's 9 degrees here but just wanted some input. Thanks
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
@westhavensean,Sean, It will probably be a rusted out/damaged fuel line or connection. You really should discontinue/restrict your driving until repaired as it could be a fire hazard waiting to happen if you do not wish to address the repair yourself. Have a reputable shop have a look and estimate repair.Good luck.
해당 답변은 도움이 되었습니까?
점수 2
댓글 1개:
I'm having the same problem with my 2005 Cavalier gas in the air box I had a crack in the side of my fuel pressure regulator line thought maybe that was the problem fixed it still doing it fixed another vacuum line thought it might help but it didn't so me too and trying to figure out where the hell all this gas coming from
댓글 달기
귀하의 답변을 추가하세요
Sean Rasmussen 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 11
전체 시간: 583
