주요 콘텐츠로 건너뛰기
Lapttop not connecting to projector screen
My laptop has stopped working with the projector. The projector works with another laptop. What is on my laptop desktop does not display on the projector screen. Tried holding down the FN key with all the other F keys.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 3개:
What model is your projector?
It is an Optoma. My friend's laptop is working fine with it.
My laptop has worked with this projector many times before. Today is the first time I have had this problem.
댓글 달기
답변 1개
You said your projector is worked on another laptop, so the projector is find, so i think this laptop maybe had no projector driver. So try to connect the projector to the laptop, check all the port and then enter the device manager, try to install the projector at first. And you can view here to learn how to install drivers. If the two laptops has the different system, you'd better see the system this projector support. Because some old projector maybe not supports windows 8, windows 10.
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
Found out from a kid that all I needed to do was go to control panel display and it select play on another screen.
댓글 달기
귀하의 답변을 추가하세요
harobed1170 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 12
전체 시간: 1,370
