주요 콘텐츠로 건너뛰기
Apple iPhone 5s는 2013년 9월 10일에 발표되었습니다. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 16, 32, 또는 64GB / 은색, 금색 및 스페이스 그레이.
3530 질문 전체 보기
Wifi - Periodic "No internet connection", Reboot to Fix
Periodically, my iPhone 5s will lose its connection to Wifi. When I go into Settings, it recognizes my Wifi network, and is trying to automatically connect to it (because it is a known network). However, underneath the network name the phone displays "No Internet Connection", and will never connect. After rebooting, the phone will connect to Wifi when I unlock the phone and go back to the wifi menu in settings (It will display LTE until I physically go into the wifi menu), but the process will start all over again after a while (e.g. 24 hours).
There has been no water damage or drops. Phone is in good condition. The wifi network is working normally, because other devices are connected and receiving regular internet service (e.g. Computers, amazon echo, apple TV, etc. - devices without cellular service).
Any thoughts?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
First of all, try to restore it through iTunes. If the problem is still there then you would probably have to troubleshoot it on a hard-ware level. As far as I know it's most likely something faulty on the motherboard when it comes to these wifi "sometimes" problems. If it had to do with the antenna the problem would most likely always be there.
Also, if you restore it through iTunes and it turns gray then its definitely something related to the wifi-chip.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Tim D 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 7
30일 전: 11
전체 시간: 495
