How do I remove internal D pillar trm
to replace rear seatbelt
좋은 질문 입니까?
@jethro49er, Terry, Normally they have clips just like the others. I used a V-pry/ long screw driver and a flashlight to locate the clips from behind. Use the screw driver to apply pressure. It keeps the clips from breaking off. The 1st link to manual below may help, 2nd link is the different D piller trim you may be able to see the clips,etc. Good luck.
해당 답변은 도움이 되었습니까?
해당 답변은 도움이 되었습니까?
24 시간 전: 0
7일 전: 2
30일 전: 11
전체 시간: 118
댓글 1개
@jethro49er what year is your Range Rover
oldturkey03 의
